9166188
Thank you Themk! You are very right and you said "one should be able to connect the R,G and B lines all together to get white" and "you may not need to amplify and split the signal, just electrically connect them all together". So, lol, actually I was following your direction. :b&w:Sweet! That's what I thought was the problem, glad to know you were able to test it! Congratulations on your breakthrough! It's also good to know that my idea regarding not needing a split and amplify circuit also works.
BadGoldEagle, I think the card is monochrome.
Eagle, it's a monochrome card. I wish it were a color one like yours. My card came from a SE/30 and I was hoping that it could work with my 13" Apple High Resolution CRT out of box. Unfortunately, the card always insists on 680x864, to the extent I think it's hardcoded to be the only supported mode. Do you think this is the case with your IIsi Color Pivot? I still would like a color card to work with my Apple CRT.
