Trash80toHP_Mini
NIGHT STALKER
Worked out the grand scheme of things in two previous incarnations of this guerilla campaign. So the goal is in sight and it's been time to do the work.
Took one big step back from the mock-up to begin a serious project: Reworking a riser/right angle adapter card for the IIsi that I knew wasn't going to work as was. I tried it on a lark way back when, got nada, but figured it wasn't a true PDS Passthru as it had been specifically designed to adapt a SuperMac Video Card to the IIsi PDS form factor, not as a general purpose PDS Angle Adapter/Passthru kind of deal. Turned out to be right, lots of control signals missing, not hard to patch, but I got bored. :
Was looking at the assemblage and wishing this or that weren't in the way and it hit me: who needs a friggin' chassis for a test setup anyway! HEH!
Bolted the clear inner shell from a test rig for another backburnered hack from waaaay back when up to the Chassis/AB/PSU of the SE/30. Marked out the four drill points for mounting it to the AB/PSU and then bolted it right up without that dang chass!. It was plenty stable with it's snaggle-toothed edge tucked up inside the nicely notched rearedge of the front bezel, but figured I'd still manage to knock the thing over right on top of the MoBo. Fabbed a quickie bottom plate that inserts into the slot at the bottom of the back of the Front Bezel, duct taped the three sides of an empty box together and went to town!
Was ready to plug the NuBus Adapter in when I remembered that blasted FPU, so I fired up the hot air rework station and promptly set the smoke alarm above my head to wailing (note to self: find a new spot to do hot air rework) and beat a hasty retreat, smoking card in hand into the bathroom to turn on the exhaust fan. Curses, foiled! Dropped the smoking card (fresh from its anti-static bag) to grab the one I've been pawing over for months without an anti-static care in the world and chopped that FPU's legs off with a handy knife!
h34r:
It was ugly, figured it might have a short, but I popped it in and fired up the SE/30 anyway to a great death knell. Cleaned up the mess a bit and got a startup chime and this for video output.
Installed and hooked up the Radius Color Pivot II/IIsi to the KDS/Radius LCD I've been using for testing, checked this or that, made sure the magic smoke was still where it belonged and now I get repeatable results. Thought maybe I'd get video on the LCD despite mobo video borkage, no joy there. Hunky-dory without the IIsi NuBus Adapter, startup bong and the same memory interference pattern on the monitor with the NuBus adapter plugged directly into the logic board or into the RCPII/IIsi with its full on PDS Passthru implementation. Nice thing that!
Here's another shot of what I get:
One of the times I removed the NuBus Adapter to reboot without it, the pattern had persisted in video memory, being wiped away with the successful reboot.
Now if just ONE of my FOUR friggin' IIsi boards worked to verify function of this particular NuBus adapter I'd say I had some interesting results to show, but this way it's only a sneaking suspicion:
NuBus in SE/30 will work but it will require a Slot E video memory conflict fix along the lines of the active component PowerCache adapters.
That's my WAG and I'm sticking to it! :blink:
