PowerPup
More of a hardware "repair" than a hack. I was getting tired of how my cheap Philips CD-Rs just wouldn't work in my PowerBook G4 no matter what speed I burned them. So it got me thinking, the reason why game consoles (esp. GameCubes) often stop reading discs is because the laser's POT (resistance) is either too high or too low. Thus making the laser too weak or too strong to read the disc. (This happens due to age/wear, improper calibration or both.)
I noticed that these Philips discs are extremely transparent compared to other CD-Rs. (I'll add a comparison pic later.) Because the label's side coat was so thin, I assumed the laser was so strong that it was just shooting pass the disc.
So I cracked open my PBG4 and opened the lid off the DVD/CD-RW combo drive, quickly locating the pot on the side of the laser mechanism. Taking my multimeter I found out the resistance was set at 150-Ohms. So I kept increasing the resistance (thus reducing the strength of the laser) in increments of 30-50 until it was reading the Philips discs perfectly every time. (Double the original setting, about 300-Ohms. This also happens to be around the "sweet-spot" for GCs.)
So by lowering the strength of the laser not only have I gained the ability to read cheaper discs, but it'll likely extend the life span of the drive as I'm not burning out the laser as quickly.
(I've also tested DVD videos in it and they still work fine.)
Note: This is only testimony of my personal experience and in no way am I an expert on the matter. Use this technique at your own risk!
