jmacz
I've got a 5300c and a 5300cs, but only one power brick (which is working ok so far). I want another. 24V power supplies with at least 2amps are plentiful. For the male connector, it looks like it's a 3.75mm outside diameter by 1.3mm inside diameter. This doesn't seem to be a standard size. The closest one I see is a 3.5mm outside diameter by 1.3mm inside diameter. I've ordered one of these just to test fit (0.25mm difference). Has anyone gotten a replacement modern supply working if so, what size barrel plug did you use?
The other alternative if I don't want to use the stock charger anymore is to open up the laptop again and replace the power port with a standard 5.5mm port. The chassis hole is definitely large enough to clear.
