Powerbook 180c startup problem
Ralphieboy
Hi. I am rebuilding a PB180C.
Screen capacitors have been changed.
The machine boats a SCSI2SD, a custom 10Mo Ram expansion card and a new PRam battery. The main battery has a 1 minute autonomy.
However, each time I disconnet and reconnect the main power supply the machine does not want to boot anymore.
I usually have to reset the power manager and/or perform some voodoo tricks with the battery and power supply and reset button.
Can somebody help me with that?
MOS8_030
Just guessing I would say the dead main battery is preventing the PRAM battery from being charged.
Ralphieboy
Unfortunately I don’t think so.
The main battery is not actually dead, it holds little charge (1 minute, maybe less).
In fact I kept it in the machine in order to charge the PRAM battery.
MOS8_030
I believe the PRAM battery in these PB's won't charge until the main battery is charged to a certain level.
