Schorschinjo
My Sawtooth G4 400MHz AGP won't bootup anymore.
Only yesterday, I started the machine and it started as before. Today, in (likely) same setup, it does not startup anymore.
The power supply fan starts spinning. But no chime, no video.
Meanwhile I removed the SCSI card, the SATA card, the ethernet card, the ATI AGP graphics card, all of the SDRAM, the PRAM battery, reseated the CPU, unplugged all ATA drives and pressed the reset button on the mainboard several times. (while plugged, while unplugged, while "running", with battery, without battery). Attached a firewire drive, but it did not help as well.
The hard drive does not start spinning, when it is connected to the ATA bus. When I unplug it from ATA, but have power connected to the HDD, the drive starts spinning. Same applies for the DVD-drive: When connected to the ATA bus, it won't react to pushing the open tray button. When only connected to power, the tray opens upon pressing the button
Could it be, that the ATA controller is somewhat locked/held in reset?
Does anyone have a hint or a link?
Thanks in advance!
BTW: I bought the machine earlier this year and bought a G4 Sonnet Encore 1.8GHz upgrade for it soon afterwards. With this beast installed, the machine ran MacOSX 10.5 fine and stable. But when I switched to MacOS9.2.2 or MacOSX 10.4, soon, the machine froze. Therefore, I removed the G4 upgrade and had it running stable with the original CPU.
Thanks in advance!
