PowerBook 150 totally dead
Pinstripes
I dug up my PB150, but it completely refuses to boot. The battery died so long ago it's not funny, but I have the big brick ac adapter.
I've hit the switch on the back (reset?), tried it with the battery in and out, and let it sit for a while. Nothing. Is it just a paperweight now? :'(
Byrd
My approach to fixing "dead" 1x0 Powerbooks
- Pull battery
- Leave plugged in for a few hours
- Hold down power button/rear switch, press on and off
- Should chime, then die - power up again, it should eventually get to start up.
- Plug in battery, it'll switch off
- Turn off PB, plug in battery, repeat several times
... I think the battery screws up PRAM settings if not used for a while, with trial and error similar to the above you should be able to get it to boot without the battery, then "coax" it back into recognition
JB
