The 1400 is limited to 64 megs of RAM and MacOS 8 adds a lot of bloat over 7.6.1 and the minimum requirements are higher, so that offsets any speed gains to be had from using native PPC code. The 603 is no speed demon, either. It was the replacement for the 601 at the bottom of the PPC family. Head over to System 7 today and you'll see many of the members there use 1400's with 7.6.1 and get good use out of them.i always thought the speed gains were to be got from running os8.5 due to it being ppc native - no?
over and above ram considerations of course.
you know - looking at those results i would still go with 8.5.[And here's their speed benchmarks comparing 7.6.1 to 8.1, 8.6 and 9.1.
http://main.system7today.com/articles/til/benchmarks.html
I ran 7.6.1 for a while on mine and found 8.1 to be more stable.i'd run 8.1 personally, if for no other reason than HFS+ and the better looking UI.
I always thought they were rare and expensive. Luckily, I just picked one up, as well as a c screen, a video out card and a spares machine.easy to come by and cheap G3 upgrade in there and we can argue if 8.6 or 9 is better!
I thought about it but went with a Wallstreet instead. Now my 1400 does see much use.cheap G3 upgrade
it seems my *wink* was lost!I always thought they were rare and expensive. Luckily, I just picked one up, as well as a c screen, a video out card and a spares machine.easy to come by and cheap G3 upgrade in there and we can argue if 8.6 or 9 is better!
