haemogoblin
Hey guys
So I have this problem, I have a G4 500Mhz Pismo, running 10.4.11. When ever I try connecting to the wifi at home it will report I have entered the wrong password, which I know isn't the case. I've run the latest update 10.4.11 combo, which I understand fixes this problem. But it's not done anything for me. The airport card works fine with WPA encryption on my GF's router, so i know WPA works on this laptop. But when I try using it at home on my own router, for some reason it will not connect. I've tried setting it to WPA TKIP or WPA auto, it used to work before we had our broadband upgraded. Which involved our router/modem being replaced with a new model. In the past on the Superhub v1, I just had to disable WPS and the Pismo would log in without a problem. But this new unit seems different, its setup for WPA encryption with WPS disabled, but still the Pismo tells me I'm entering the wrong password.
Now I realise this is a long shot, as it is unlikey anyone on here will be using the same router/modem as me, but I thought there might be a possibility that someone has had WPA issues with their Pismo.
I've tried wiping the keychains, manually creating a connection in preferences and telling OSx to connect to the preferred network, but nothing works.
If anyone has any thoughts, I'd love to hear them. I'm reaching the point where I've exhausted all my options and I'm thinking the only solution will be to replace the router.
