MacUp72
at the moment I'm trying to get my 1400 somehow connected to the internet under OS 9.1 but no success. I have three WLAN cards just for getting any connection, a Cisco Aironet 350, a Enterasys RoamAbout DS CSIBD-AA-128 and a iWavePort WL11A. The RoamAbout is actually a rebranded Orinoco, it shows up as 3rd party gold Card.. the WL11A is also listed here as compatible, it is also Orinoco based.
I had success with the Cisco in a wallstreet without any problems and could connect, but didnt work in the 1400, so from now on only the two Orinoco based cards:
I tried many Orinoco drivers that are available and used MacTCPWatcher to ping and test any network activity. I use an older Airport Express router LAN wired to my actual O2 DSL router. as a reference, I used this exact setup 6 months ago with another 1400 I had at the time together with an original Orinoco Gold I had at the time (from memory I just set it up manually and then it worked).
The WL11 card also lights up, I also can see a strong signal in the Orinoco control field ( when I start it from apple control fields, but when I click on the Orinoco control strip symbol the system freezes.
the setup now:
I setup the Airport Express as a new network with WEP password ( did work with the old setup), I can see the Pv4 adress and router adress, router modus off ( bridge modus), it is LAN hardwired to the O2 router. I rechecked it in the actual O2 router with the browser and I correctly can see LAn or WLAN connections. The Airport Express is shown there as LAN, to test this I connect with my MacBook Pro to it via WLAN and it works ( I can switch between my WAP2 and the new WAP (W)LAN).
I then use only the RoamAbout card as this seems the most stable, I installed the latest Orinoco driver 7.2. as this gets me the most results up to now.
I also used the only available RoamAbout driver but it didnt show up correctly ( just as Ethernet, not WLAN ) and I didnt get any network scanning.
with the Orinoco 7.2 driver the RoamAbout card shows a steady green light ( the led next to me) after boot, it shows up on the desktop as Orinoco, and Orinoco shows up under TCP/IP, no freezes on the control strip. on Orinoco setup, I can see not open networks : Current network-scanning-, no signal strength
TCPWatcher reports it has no DNS ( host name does not exist)
Maybe it really is still just a wrong TCP/IP setting that prevents it from working![Roll eyes :rolleyes: :rolleyes:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
the setup now:
