Couldn't find a general section for this question so since it was an SE30 thought I would post here. I have about 8 or so traces that still appear to have the protective layer on them and they do ohm out okay, but the trace is corroded looking underneath. What is the proper way to handle this? just make sure you soak the board in a mild acid to neutralize the cap goo, or do I need to take off the protective layer to clean the trace before re-applying with an overcoat pen? Just don't want to overthink or do unnecessary things that might end up causing more damage.
