3lectr1cPPC
Well, that is likely true for audio gear. Don’t know much about it but I do know that cap quality and type can matter a lot. There’s nothing wrong with going all electrolytic, but do keep in mind that there’s basically no instance of electrolytic caps staying in spec over periods of 20+ years. Not all leak like the late 80s/90s ones can, but I’ve heard accounts of electrolytic caps as new as 2009 era already being out of spec. Tantalums stay working a lot longer. They usually fail short, where they might explode a bit, but in most cases, instances of this are rare, and won’t happen till they’re at least 30 years old, so I prefer them. Most of us do use tantalum caps when recapping. Those who use electrolytics usually do so because they prefer an original look to the board, not any other reason. I certainly don’t know much about the nuances of capacitor type though. There’s a lot of stuff like tolerances, heat, ESR, etc. that can be important depending on the type of circuit (like audio gear especially I’m sure, and in power supplies).
What I can say is that after the recap, my 3400c does have an extremely minor audio issue that wasn’t there before. I described it on my website, basically, it can distort a bit for a second or two when it’s starting up, but only sometimes, and by the time it’s booted it’s always gone. Could be related to the caps I used, no idea. It is quite literally so minor though that I do not mind it a bit, and would use the same caps again on another system.
