Macintosh IICi No chime and blackscreen
Elv1s
The three 74HC logic chips, right? In my case the middle one failed without any visible signs of corrosion. I even desoldered it, cleaned up all the traces and re-soldered it down. I am sure it was killed by cap goo.
The chips looks to be fine, little to none corrsion.
Elv1s
Elv1s
JC8080
If you have a hot air gun, great. Otherwise, I recommend ChipQuick desoldering solder. Yes, it is expensive. So, get the smallest amount you can. It is useful in almost any stubborn electronics situation. It is just solder with a low melting point, so it stays molten long enough to 'float' off the chip with just a soldering iron.
I keep ChipQuik around as a standby, it does work well in many situations, you can buy a small kit from Amazon (link) for $11.95. Personally, I recommend picking up a hot air station, I bought mine from Amazon for $40 (link). I'm sure there are better ones out there, but this one has adjustable temperature and fan speed, as well as swappable nozzles. I end up using it quite often. If you will be removing the type of SMD ICs with the legs that curl underneath, I believe a hot air station is necessary. I tried ChipQuip on that style of chip once with no success, though other people may have different experiences.
Elv1s
I have all the tools (not including an oscilloskope)
