PB3400 wont start
MacUp72
today I got a nice working Pismo 400 and a 3400, but this doesnt start at all.
I already removed the PRAM battery, tried reseating everything, starting only with necessary hardware, but it doesnt even try to chime.
I only can hear a tiny Pop from the speakers. Power adapter is working, the battery looks very good, no corrosion anywhere.
Maybe the power connector on the board is cracked/bad, at the moment I try to remove the logic board to check for cracks or bad solder there.
but I cant get it out of the chassis...
the manual is a joke ( with modern powerbooks this is easier)
3lectr1cPPC
Getting a 3400 logic board removed is a real pain - I've done it and it involves a lot of finagling to get the darn thing out. I attack it near the area where the power board connects (bottom right, like the manual says, although I never even read it haha). First objective is to get the headphone jacks free from the case, then keep pressing right and forward towards you and eventually it will pop loose. Feels like you're going to break it and it bends slightly in the process, but there isn't a better way I know of. Neither of my boards suffered damage though.
As for why your unit is dead, most likely suspect is the DC power board (board with the battery contacts on it). Start with replacing the two capacitors on it and hope to god it's that, but it often isn't from what I've heard. Something on them can just go bad.
The other suspect would of course be the PRAM battery. You said the battery hasn't leaked, are you talking about the main or the PRAM? The main won't, it's lithium ion. double check the board under the PRAM battery, maybe you missed something, but if it isn't that, then I'm afraid you've likely fallen into one of the classic 3400 failure modes. You can try resoldering the DC jack but I honestly doubt it's that.
MacUp72
no PRAM didnt leak, the black cable did come off though..nothing on the board either.
Battery looks ok, no corrosion.
do these look bad? not too swollen..
MacUp72
ok, just found some corrosion under the PRAM battery, cleaned and scrubbed it with alcohol but no change..
strange, because the PRAM battery from the outside didnt leak ( I can see a corrosion inside the two PRAM cables though)
bummer, because it has a CD drive..well better turn my attention to the Pismo now..
thanks
PS, good site of yours
MacUp72
when I plug in my modded G4 power adapter a wiggle it a bit, the little led at the top of the monitor gets green.. at least:p
3lectr1cPPC
Funny thing is that it isn't actually supposed to do that - that light is just for blinking during sleep. If it's on solid, that's known as the Green Light of Death, which is almost always a power delivery failure of some kind, ie, the power board. Seeing as you have to wiggle it, give resoldering the DC jack a go. If you're lucky, that will be the only problem.
MacUp72
ok, I'll try a recap..on your reference site you already seem to have photographed some changed caps..
I'm not an cap expert, maybe you kindly could make an mouser ordering list with your correct cap models
eg, the 100uF 35V seems to be this one, but your two 33uF 25V ? you have replaced both 33uF to Tantalum ones..
many thanks
I also noticed theres a little bit of whitish covering on that coil on the left, this maybe normal, but I dont know..
( have seen exploded cabs with the gut spilled over a board, but I cant see anything of this here basically)
3lectr1cPPC
that doesn't look quite right to me based on the image I have of my power board, but it's hard to tell. I'll go through mouser and try to assemble a parts list, although I won't be able to validate 100% that everything will fit.
3lectr1cPPC
Pretty sure these are the 33uf caps I used (get two): https://www.mouser.com/ProductDetai...GAEpiMZZMsh%2B1woXyUXj9KDAa7IpJRW6/lC1SHudFk=
pretty sure these are the 100uf 25v caps (get one): https://www.mouser.com/ProductDetai...EpiMZZMsh%2B1woXyUXj4jKQI6sNRw62TrqU%2BXpeYs=
Display: Not sure which exact ones I ordered, just bought ceramic caps because they're small and there is extremely little space to solder on the LCD. You aren't really supposed to use ceramic caps on displays because it can cause problems on some panels, but they worked fine on mine. Here are ones with matching values, will probably fit because I just found two that matched the value and bought them when I ordered myself, but there's always the chance that they may not, hard to tell.
200uf 4v: https://www.mouser.com/ProductDetai...GAEpiMZZMsh%2B1woXyUXj1nTw/Km/cPwvOtv47gDNio=
22uf 16v: https://www.mouser.com/ProductDetail/KYOCERA-AVX/1206YD226MAT2A?qs=ICeuwU4uWg30c4w3mpe%2BkA==
Inverter board:
10uf 50v, fairly sure these are what I bought: https://www.mouser.com/ProductDetail/Vishay-Sprague/293D106X9050E2TE3?qs=N31o%2Bt096gu9lsvzLRhHsg==
2.2uf 50v, ceramic cap because it needs to be small. Don't remember ordering a Samsung cap before but it should fit as these ceramic caps are teeny tiny: https://www.mouser.com/ProductDetai...EpiMZZMukHu%2BjC5l7YRMZipZFyP%2B4GmTuMs4UQeM=
There you go, no guarantees but these should work.
MacUp72
very sorry, but your links dont work ..
you coud just copy/paste the partnumbers..
thanks
3lectr1cPPC
That is very strange. I get an error as if the site is down from my phone, but the site and links work fine on my computer. Hmm.
3lectr1cPPC
MacUp72
maybe its a good idea, if you just paste the parts/article numbers..not links or your list.
I look it up myself at mousers germany, also was loking at Conrad but these look very different and are not available..
3lectr1cPPC
Same error I was getting...
Part numbers:
74-593D25V33D
710-865080545012
581-F950G227KAAAQ2
581-1206YD226MAT2A
74-293D106X9050E2TE3
187-CL21B225KBYNNWE
MacUp72
interesting, while researching for other sources for those caps I chatted with my cousin, an experienced electronic specialist/ serviceman ( he rapaired TVs, HiFi, Pc, amplifiers etc for 35 years).
He said, he would NEVER replace those old SMD eletrolytic caps with tantals, tantals were thought to be something special a few decades ago, but they turned out as inferior. He NEVER replaced elkos with tantals in his shop for clients.
The build quality of todays elkos is much higher than before, I now just replace it with 105 degree electrolytic ones, in particular the 100 uF 35V.
he is 80% sure in the case of this power board it is these two old elkos..
