Mystery IIsi that chimes, but has no video, and won't boot!
franklyn
I also had the problem that the start sound was fine but the computer didn't bring up a picture onto the monitor and didn't boot. The reason was bad contacts (oxidized) on the video controller chip. New/re-soldered and now everything is good ...
On other computer systems there are diagnostic modules and a null modem serial connection to another computer with a terminal program. Is there something like this for the Macintosh 68k series?
Garrett B
When you say "video controller chip" you're talking about the RBV chip at UA3?
Garrett B
You bring up a good point here. I've done some serial diagnostic work on a Portable but didn't even think to try the IIsi. I know it's supported - just need to figure out syntax for the right tests to run. Unfortunately a lot of this isn't super well documented. I'll post back though when I have a chance to get serial set up. That is, if serial is working. Fingers crossed!
