Quadra 610 - Onboard Video Ram?
I have a Quadra 610 I'm working on. No battery leakage, but obvious failed caps. I've replaced all the caps, but afterwords the machine doesn't boot, no startup chime and no video.
I've found conflicting information online as to if the 610 has any onboard video ram. Looking at the motherboard, I'm thinking that it does not. Does anyone know for certain?
If the 610 doesn't have any on board video RAM, and no video RAM installed, would this prevent a startup chime?
It does have onboard VRAM, it is next to the ROM at the front edge of the board, slightly to the right of centre.
Forrest
Confirming the 610 has 512KB of VRAM soldered to the logic board. There are also two memory slots where you can install a pair of 256KB VRAM modules, bumping the VRAM to 1 MB. There is some debate on whether a PRAM battery is needed on this model, but it couldn’t hurt installing one.
Fantastic, thank you both for confirming. I've tried booting it with a PRAM battery installed, but I've realized now that I didn't test the voltage on the PRAM battery so I might have been testing with a bad battery. Something I'll double check this evening.
Appreciate the quick replies!
