I got the Performa 575 parts moved into the Macintosh TV and it's up and running.
I used the Performa 575 as a test bed for the Mac TV analog/logic and the LC 520 analog/logic, as well as the extra analog board that I bought.
As it turns out:
- the Mac TV analog and logic boards are both dead
- the LC 520 analog is dead but the logic is good
- the extra analog board that I picked up is dead too
The Mac TV must have been hit by lightning or something, because everything in it was toast. Analog dead. Logic dead. The CD-ROM wouldn't read disks. It would split them right out. The flopy drive too didn't seem to work. It just complained that disks were unreadable, and then failed to format them. The hard drive was dead too. I even swapped out the CRT becasue the one in the Mac TV was burned in. You could see the menu bar at startup.
Also, the guns were misaligned becasue none of the colors matched up. The display was slightly rotated and jammed up to the top left hand side.
I think the only thing I got out of it was the enclosure.
In the end, it's good to finally see it up and running after 5 months of trying to get parts for it.
