maceffects
Yes, if the Analog board doesn't fix the issue the main board needs replaced, and uniserver is right thats most likely what happened there.
That doesn't look too bad - it looks like mostly surface rust & deposits. It may still come up good after a clean. NB: board washing technique is something you may want to search on here if you've not attempted it before.Look at the corrosion under the tuner card:
Yeah, that's toast. Still, give it a clean and see how it looks afterwards. As Dennis says, you may be able to replace the individual components if the PCB itself is OK - and if you can work out or find out values for all the components :/look at the daughter board on the tuner card. It looks fried.
Did you ever try with the remote ? as far as i know you have got one and if something is faulty in the keyboard side, you probably will be able to by-pass it.I have 4 different keyboards and nothing works
