GreenBar0n
Glad to have found this site, I've already learned a lot from the previous posts here. I'm currently wondering about recapping this SE, and which boards are mandatory.
I was given this SE about 15 years ago, it was known to power up, but to only produce the Floppy Disk picture with the question mark on screen.
When I opened this SE, I found someone had added an HDD.
I had to open the HDD to get the motor to spin the platters, it was stuck and wouldn't rotate. I can get the motor to turn, and the heads will seek, and the head will wave back and forth, yet still not boot.
Ordered the BlueSCSI v2 kit with Wi-Fi for this, and a PRAM holder and battery, because this is the early SE with the Varta.
Someone added 4Mb of the Goldstar labeled RAM, and cut the 256k bit resistor.
A visual inspection of the electrolytic caps shows none of them are physically damaged or leaking, but I know the internal ESR or values may have wandered in the last 40 years.
Based on the condition of this unit, what boards would be a mandatory, or would be best, to recap?
Thanks!
Thanks!
