wildstar1063
Well, I finally got my Mac SE/30 to boot after I took it down from my attic. it had been up there for at least 12 years. When I took it down, I pulled the battery which fortunately had not exploded over the logic board. Since taking it down, I have recapped the logic board and the analog board and now it will boot, but I've only been able to get it to boot from the ROM image included on one of those Purple ROM's.
The first thing I found after getting it back together was that the old Quantum hard drive has that issue where the heads sticks to that gooey thing underneath the platters, and that the floppy drive had been setting for so long it was nearly glued together from the hardening of the old lube. So I've got it back apart again and have cleaned and lubed the floppy and replaced that little gear with one purchased from a seller on eBay. I am currently waiting for this item-
To arrive from eBay, to see if it will fix the issue with the old Quantum Drive. I worked at Seagate building hard drives, in the clean rooms, here in Oklahoma City from 1989 up until 2000, so I wouldn't be afraid to take the thing apart and replace the bumper if I had to, but I thought this would be worth a try.
I've got several versions of Mac OS and a bunch of old disc tools on 3 1/2 inch floppy that I used on my.A-Max Mac emulator on my old Amiga 3000 back in the 90's, if the disks are still good, so hopefully, I will have some tools to work with.
I am diabetic and have problems with my eyes due to that, so in order to recap the logic board, I bought one of those little cheap microscope cameras with built-in 10 inch screen from an eBay seller, which helped immensely with the soldering. It took a bit to get used to it, though, and I think I managed to touch the edge of most of the connectors with my soldering iron ;-) due to the field of vision of the microscope, being too small and not paying attention to where the rest of the soldering iron was. But everything still works.
Once I get everything back together again, I'll post some pictures of it working.
Chuck E.
Chuck E.
