bigmessowires
After more testing, I think the voltage divider R4/R5 is making things worse rather than better. The intent was to reduce the Mac's composite sync output to a voltage similar to a composite video signal - about 1 Vp-p. But when combined with capacitor C1, I think it forms an unintentional RC filter on the signal, and in my tests the output signals looked worse with the voltage divider than without it. So I've removed it. Maybe it would work if I added a transistor emitter follow circuit between the voltage divider and the C1 capacitor to isolate them, but... screw it. It's working well when 5V CSYNC is connected directly to the C1 cap, and other designers using the LM1881 are doing the same thing, so I'll stick with the simple approach.
I've also removed the 180 ohm series resistor on the VSYNC output. My testing was all done without a resistor there, so I'll keep it that way.
What are the chances I can get this fabricated and built in the next seven days?
