LocalTalk cables: crossed-over wiring or straight-through?
Standard Apple serial cables are always crossed over, regardless of whether they are mac-mac or mac-printer.
Some third-party ones are straight-wired, for some reason, and don't work properly with anything. I assume there is some peripheral out there that liked that, but I've no idea what it was.
And I've got a third-party one here that's cross-wired but only wired for RS232, and that one is baffling.
mdeverhart
My recollection is that modems and things that follow the DCE/DTE relationship use straight-through cables, while printers and point-to-point LocalTalk use the crossover.
gsteemso
bigmessowires,
The straight thru serial cable is likely meant to be used with a manual switch box such as https://www.cablesdirect.com/store/p/2250.aspx
I had one of those "back in the day" and was initially baffled that it didn't seem to work. I eventually determined, with outraged disgust, that they had failed to cross over the wires internally to the switchbox, so I had to hand-build a straight-through cable before I could do anything with it.
So far as I'm aware, only one Apple product ever used a straight-through mini-8 serial cable, and the existence of the cable specific to that product caused extensive wailing and gnashing of teeth for many years in the 1980s. The wretched things were visually indistinguishable from all that came later, except for the tiny model number moulded into the bottom of the plug on the end, so if you were unlucky you'd occasionally get a serial cable that mysteriously just didn't work. (I _believe_, without having verified it physically, that the product in question was a very early Apple-branded printer. For a long time I'd been under the impression it was the original ImageWriter I, but ISTR later discovering that those didn't even have a mini-8 connector, so now I really have no idea.)
