I've found 64MB SIMMs at Memory Ten, but so far nothing bigger. Something tells me that 68MB in a 575 might actually be plenty ;-)Chris Lawson's research is reported at:http://macfaq.org/hardware/memory.shtml
Locating a suitable SIMM today may be more difficult, so be prepared to buy a few and make sure that you have a generic PC or whatever in which to install the majority that don't work. SIMMs identified as working in a PowerMac 6100 or Acorn RISC are a decent bet.
At the time the LC575 was released the maximum memory size per SIMM was at 32MB's Today you can purchase SIMM's of 128mb'sAccording to most docs the LC575 maximum RAM is 36MB, though I've found a few mentions of 68MB being possible... I wonder if anyone's done this (or more?) and how it turned out. Any stability issues?
Um, I'm really looking for a 128mb module for my Mystic CC so I was about to jump on this but then I realized that this is 60ns. Many sites (including low end mac: http://www.lowendmac.com/500/performa-575.html) list the machine as using 80ns RAM. Is the 80ns a minimum or maximum? How much would you expect speed to deteriorate using 60ns?Just posted this on the Trading Post forum, but thought I'd include it here, too:
I found a pretty good deal on eBay for 128MB SIMMs that I have confirmed are compatible (and small enough to fit properly) in the LC 475 / Quadra 605.
Samsung 128MB 32x36-60ns ECC SIMM KMM53632000AK-6U
$13.50 each with free shipping
http://cgi.ebay.com/Samsung-128MB-32x36-60ns-ECC-SIMM-KMM53632000AK-6U_W0QQitemZ110331791958QQ
My guess is these would also work fine with the LC 575
The auction indicates the seller has more than 10 available.
This module seems to be of "parity" type. Could someone please confirm it does work and fit properly inside a LC 475? Uptil now I was not lucky with parity EDOs in my LCs. Also this module is not what I would call a low profile module. It might interfere with the case of a CC (even with proper clearance inside the case a problem might occur when you try to slide in the mainboard.Samsung 128MB 32x36-60ns ECC SIMM KMM53632000AK-6U
The 6100 shipped with a 256MB hard drive 8-oA 6100 with 264MB of RAM / is a trip. So is a Quadra 840AV with 512MB
use a RAM disk
This module does fit properly and works perfectly inside a LC 475 (see the rest of my previous post here). I can't speak to the possible clearance issues in the Color Classic, however.This module seems to be of "parity" type. Could someone please confirm it does work and fit properly inside a LC 475? Uptil now I was not lucky with parity EDOs in my LCs. Also this module is not what I would call a low profile module. It might interfere with the case of a CC (even with proper clearance inside the case a problem might occur when you try to slide in the mainboard.Samsung 128MB 32x36-60ns ECC SIMM KMM53632000AK-6U
Very nice: "strong buy!"This module does fit properly and works perfectly inside a LC 475 (see the rest of my previous post here). I can't speak to the possible clearance issues in the Color Classic, however.
