Elfen
With help with from Uniserver, I decided to recap my SE/30 PSU as he determined and evidence shows that is where the Humongus Fish Smell is coming from. And on my thread, he posted up a pic of the caps that need replacement in the SE/30 PSU. So I started to look them up and ran into an interesting situation: Caps for the same rating by different and even the same manufacturer come in different sizes. Thus it comes to a situation - is a physically bigger cap better than a smaller one with the same rating? Is a thin tall cap better or worse than a short fat one with the same rating? Note - there are a few that are the same size, so is this one a "standard size" for such a cap?
Here's a partial listing from Mouser.com which I was looking at and found this:
(Note: I am not affiliated with Mouser in any way, I was using them as a resource to look up the caps in question. In this list, I removed other details such as price per unit as we are discussing cap sizes for the same ratings and not its pricing. Sometimes buying cheap is a bad thing. So here it goes...)
Capacitor Type:
Aluminum Electrolytic Capacitors, Radial - Can Type : Leaded, 4,700uF, 16volts
Manufacturer:
Mouser Part # : Manufacturer Part #
Description: (Size in mm)
Nichicon
647-UVY1C472MHD : UVY1C472MHD
Nichicon
647-UVR1C472MHD : UVR1C472MHD
Nichicon
647-UPW1C472MHD6 : UPW1C472MHD6
Panasonic
667-EEU-FR1C472L : EEU-FR1C472L
Panasonic
667-EEU-FR1C472 : EEU-FR1C472
Nichicon
647-UHE1C472MHD : UHE1C472MHD
Panasonic
667-EEU-FR1C472B : EEU-FR1C472B
Nichicon
647-UPS1C472MHD : UPS1C472MHD
Panasonic
667-EEU-HD1C472 : EEU-HD1C472
Capacitor Type:
Manufacturer:
Nichicon
Nichicon
Nichicon
Panasonic
Panasonic
Nichicon
Panasonic
Nichicon
Panasonic
