bottleworks
Hello.
For those with an Apple Network Server 700 series, I thought I would post photos of the power supply and a P/N listing if you need to rebuild your power supply. There are quite a few caps. It should be noted the the ANS 500 power supply is truly a different power supply. I had assumed that Apple would have used the same power supply, but hard wired the 500 and removed the handle, but no. Apple had a different supplier make a different supply. (Why?). In this post, there are photos of the supply for the 700 (the hot swapable design). The capacitor list is only for this unit. In the next post, I'll also post internal photos of the 500 supply, but I haven't recapped that supply at this time. The 700 supply also requires non-common rivets. They're McMaster-Carr P/N 97447A167.
I believe that should be all of them.
Quantity | DigiKey Part Number | Manufacturer Part Number | Description | Customer Reference |
2 | P19621CT-ND | EEU-EB1V221B | CAP ALUM 220UF 20% 35V RADIAL | C72, C82 |
1 | 1189-25YXM100MEFR6.3X11-ND | 25YXM100MEFR6.3X11 | CAP ALUM 100UF 20% 25V RADIAL | SIDE BOARD |
1 | 495-6061-ND | B41890A5108M000 | CAP ALUM 1000UF 20% 25V RADIAL | |
1 | 565-3595-ND | ELXS451VSN221MQ40S | CAP ALUM 220UF 20% 450V SNAP | MAIN 2 |
1 | 565-4457-ND | ETXH451VSN331MR50S | CAP ALUM 330UF 20% 450V SNAP | MAIN 1 |
1 | 1189-1630-1-ND | 35ZLJ47MTA5X11 | CAP ALUM 47UF 20% 35V RADIAL | C96 |
1 | 56-MAL217256392E3-ND | MAL217256392E3 | CAP ALUM 3900UF 20% 25V RAD TH | FAT CAP IN ARRAY |
8 | P14369-ND | EEU-FR0J562L | CAP ALUM 5600UF 20% 6.3V RADIAL | CAP ARRAY |
3 | 1189-50YXM10MEFR5X11-ND | 50YXM10MEFR5X11 | CAP ALUM 10UF 20% 50V RADIAL | C92, C98, C33 |
