Elfen
Did some recapping of boards and an LC Power Supply (PSU) today. I had a few successes here and there. Thus I post a few things I learned in recapping my first LC power supply though I am already used too such similar jobs.
The problem I had was the size of the caps. Uniserver's webpage ( http://maccaps.com/MacCaps/Capacitor_Reference/Entries/1990/10/15_LC_I%2C_II%2C_III_Power_Supplies.html ) was very beneficial and informative to this cause, but this is only a partial recapping which is fine with me. The caps in the LC PSU are tall and skinny. The caps I got are short and fat, I did not take into account the physical size of the caps.
The caps replaced are as follows, as per his website:
2 - 270µf - 25V - ELNA - Long Life Radial
1 - 270µf - 10V - ELNA - Long Life Radial
1 - 56µf - 25V - ELNA - Long Life Radial
Though all of the caps should have been replaced, past posts ad discussions with him tells me that these 4 are the most problematic, and I found that they had all leaked in the LC PSU. But the LC PSU is very tight on space and the smell of rotten fish rose when I started deoldering. Furthermore I did not have a 270µf - 10V, so I another 270µf - 25V in its place. But again, the problem here was the physical size of the caps.
One of the two caps I had to have standing on its long legs so its contact to the heat sink would be minimal. Another cap could not fit into the space the old cap was in so again, giving it long legs I was able to place it in the tight space.
At least the LC PSU is working again, but I will have to recap it one more time with tall skinny caps that ae rated higher in voltage by a bit instead of short fat ones I used now. BTW - the dead PSU is now working again and a dead LC is now living once more!
