uniserver
Per James1095's suggestion i just replaced just the (Lite Brown Caps) The Brand name of these pieces of crap is (ELNA) Long-Life
These Certain caps are the only ones that are leaking.
The rest of the caps are "nichicon" brand and they look like brand new.
SO that makes 4 caps total:
2 - 25v270uf
1 - 10v270uf
1 - 25v56uf
Ok so i didn't have any of the proper values in stock
here is a cross reference of what i used instead:
2 - 25v270uf I used: 25v 220uf
1 - 10v270uf I used: 25v 220uf
1 - 25v56uf I used: 50v 22uf
been going for a couple of hours now, this psu was completely dead before.
I think its possible because its just a PSU, the values (might not) be AS critical?
1 down, 3 more to go!
Will post Mouser Links:
http://www.mouser.com/ProductDetail/Nichicon/UPJ1E560MED1TD/?qs=sGAEpiMZZMsh%252b1woXyUXj6oVn37n4HpUQFNOlPXotnU%3d
UPJ1E560MED1TD
Nichicon Aluminum Electrolytic Capacitors - Leaded 56UF 25V 105c Data Sheet 3,615
In Stock
1: $0.20
http://www.mouser.com/ProductDetail/Nichicon/UPM1A271MED1TD/?qs=sGAEpiMZZMsh%252b1woXyUXj48hmzjy2eyCpwVeMTQca2M%3d
UPM1A271MED1TD
Nichicon Aluminum Electrolytic Capacitors - Leaded 270uF 10V 105c 8x15 Data Sheet 3,449
In Stock
1: $0.24
http://www.mouser.com/ProductDetail/Panasonic-Electronic-Components/EEU-FC1E271/?qs=sGAEpiMZZMsh%252b1woXyUXj0hftmTZXYuf23sYLmGRTj0%3d
EEU-FC1E271
Panasonic Electronic Components Aluminum Electrolytic Capacitors - Leaded 270UF 25V ELECT FC RADIAL Data Sheet 1,173
In Stock
1: $0.24
here are the links for the caps i used:
B41828A5227M8
http://www.mouser.com/ProductDetail/EPCOS/B41828A5227M8/?qs=sGAEpiMZZMsh%252b1woXyUXj1SPYG7TfWbYyJLnEP7%2f9fA%3d
EPCOS Aluminum Electrolytic Capacitors - Leaded 220 UF 25V 8x11,5 SE 9,606
In Stock
1: $0.10
http://www.mouser.com/ProductDetail/Lelon/REAR22M1HBK-0511P/?qs=sGAEpiMZZMsh%252b1woXyUXjz8pyGOK%2fuWw47bPD%2f4N2Ag%3d
REAR22M1HBK-0511P
Lelon Aluminum Electrolytic Capacitors - Leaded 50V 0.22uF 20% 5x11mm Page 902
Data Sheet 8,976
In Stock
1: $0.06
Thread linked: Capacitor Replacement Thread . . .
2 - 25v270uf
1 - 10v270uf
1 - 25v56uf
UPJ1E560MED1TD
In Stock
1: $0.20
UPM1A271MED1TD
In Stock
1: $0.24
EEU-FC1E271
In Stock
1: $0.24
B41828A5227M8
In Stock
1: $0.10
REAR22M1HBK-0511P
Data Sheet 8,976
In Stock
1: $0.06
