VMSZealot
My LC475 has a dead PSU (I tested it briefly with the lower rated PSU from my LCIII and it worked fine - so it's definitely the PSU and not the logic board). There are no odd smells, no scorch marks, and no leaking or bulging caps - the PSU board looks as good as new. The fuse is fine - so I jumped to a conclusion. The RIFA caps. There are a pair - both the same - KNB1530, 0.22uF, 250V AC, X2 (date stamped, as if it mattered, June '93).
I've removed both of them - neither of them seem to test good (but that could be a limitation of my multimeter), and one has a faint crack across the bottom (so I feel reasonably sure that they have either popped or are about to - although neither are scorched).
I can't find these parts online anymore from my usual sources (I'm in the UK, and I use Mouser, RS Electronics and Farnell for preference), but Farnell seems to be close to the right spec. Does anyone have any experience of these caps? Which would you recommend I buy and why?
This is the list from Farnell - List o' Parts
