Apple ][+ Replacement PSU
PowerPCFan
I'd like to get a replacement PSU for my Apple ][+. I don't want to recap my existing one.
Would you guys recommend the universal replacement from Reactivemicro.com ??
Or even better, is there a way I can adapt a modern ATX power supply to work?
I don't want those RIFA caps blowing during my VCF East exhibit!
-Charlie, a.k.a. PowerPCFan
Skate323k137
I'll probably do that.
I just found out about this: picorc.com
I think that would work too right?
Looks like a solid solution!
I suppose pick based upon your skill, budget, and last but absolutely not least, amperage requirements. If you plan to load up every slot, pick a solution with a higher mA rating especially on +5v than your factory PSU is labelled for.
