Trash80toHP_Mini
NIGHT STALKER
. . . as if I didn't already have enough on my plate, now I'm trying hack a PC together for Mac ROM burning playtime! :
So far so good, almost. I had snagged an ATX MoBo on eBay a couple or three years back. I figured the very heatsink would come in handy even if nothing else worked, though it was purported to be good, IIRC. I have to search for the info on it here a/o pull what I've got together all apart and just read the friggin' board if it's not something basic I'm doing wrong.
I installed a new, when I bought it, unused 500W ATX PSU and plugged it in.
I hooked up the secondary exhaust fan in the case.
I located the power switch header by trial and error and powered it up.
No drives of any kind installed, just testing for RAM check, BIOS setup, etc.
Hooked it up to the Mutisync Trinitron, plugged in a wireless USB mouse nubbin and a wired USB KBD.
Hit the switch again . . . nothing but the noise of all the fans running, bopkes on the CRT. :-/
Anyway, it has PCI 1, PCIe X 1 and PCIe X 16 slots as well as a slot for a riser that I don't remember having.
A board with that kind of I/O shouldn't need a Floppy to poll in order to boot should it?
Could the missing riser card be the problem? :?:
I'll be hooking up PS/2 peripherals for a second try while waiting for feedback.
I haven't built a PC from scratch since the 386SX and CorelDraw box were waiting for the release of Windows 3.0.
TIA, gang,
jt
TIA, gang,
jt
