LimeiBook86
So I have a PowerBook 180 running System 7.1 with OpenTransport 1.1.2 installed. It works great, I want to try and get this one online, just for fun.
So I have a Macintosh Performa 6115CD with System 7.6 on it and OpenTransport 1.1.2 installed along with LocalTalk Bridge installed. My plan was to connect the PowerBook and Performa using an Apple serial cable via the printer ports, and use the software to share the Performa's ethernet connection to the PowerBook.
For some reason this just doesn't seem to work. The computers can see each other fine if File Sharing is turned on. I don't know if the Performa has a proper connection to the internet. But first this is how things are setup.
Wireless > [iMac] > ethernet cable > [Performa] > serial cable > [PowerBook]
Now before without LocalTalk Bridge the Performa was able to go online. Does having LocalTalk Bridge on disable internet access? Does it make it seem like the Performa isn't connected since it's passing the data onto the PowerBook?
Also what do I do with AppleTalk? I'm a bit confused. Does it need to be on or off? If it is on which port do I select it to. I've had it on Remote Only or the Modem port so it won't interfere with the LocalBridge Talk port (Which I assume is the printer port since that's where the cable is plugged in) Should File Sharing be on or off also?
I was reading online and some places say LocalTalk Bridge 2.1 with OpenTransport 1.1.2 will transfer TCI/IP traffic, but other say it won't and you need software like IPNetRouter or Vicomsoft Internet Gateway. Any clarification on this would be awesome. [] ]'>
Sorry if this is had to follow, it's just been a long night and I'm wondering what to do. Here is a quick diagram of the setup if it helps. Thanks!
