Apple CD 300 (SONY CDU-8003A) ejects caddy
LOOM
I got hold of a Apple CD 300 (SONY CDU-8003A) drive that turns on and shows up on the SCSI bus when I list all the devices. I when I try to put a caddy into it, it just ejects the caddy instantly. I opened it up and cleaned the laser head with some alcohol, but it still acts the same way.
After I cleaned it and put it together the caddy slot won't open automatically any more either, so I have to manually open it for the caddy to be ejected. Everything looked ok when I opened the box, no faulty hinges or anything I could see.
Does anyone have a idea how to fix it?
eraser
Have you checked the capacitors?  Based on the age of the CD 300 they are probably leaking and may well cause the drive to malfunction.
It is at least a good sign that the drive shows up on the SCSI bus though.
archer174
I just had one of these apart today to scavenge parts for another drive. There is a -very- good chance the capacitors on the logic board have leaked. There are surface mounts on the main logic board and on the board attached to the front bezel.
LOOM
Yeah, I saw a few caps on the front bezel board. They looked ok, but maybe I should try to change them. I will need to look for the other too, thanks  :quadra:
LOOM
The cd caddy slot opens when I put a caddy into it, and then the "CADDY LOADED" slot comes down, but it won't go up any more until i push it up by myself. I didn't see any switches, but maybe there is and it came loose when I opened it? Or the caps on the board attached to the front bezel board are not working and have something to do with it.
techknight
There might be a slim chance that part of this mechanism could be belt-driven.
Belts gotta be shot by now.
archer174
The drive itself should be a Sony CDU561-25. I have a teardown guide for a next drive that is very similar here: http://www.asterontech.com/Asterontech/next_cdrom_refurb.html
On your drive the inject motor will be connected by a ribbon cable to the logic board which will have a layout that is close to the one pictured. The bezel board is likely not the issue. I think the caps on the logic board are the likely suspect. Unfortunately if it's the motor itself going bad it's a full tear down to get to it, which may not be worth the effort. If after replacing the caps you want to give it a shot be mindful of the springs which suspend the mechanical parts in the enclosure. There is one at each corner. There shouldn't be belts in this drive.
apm
I have one of these drives doing the same caddy eject thing. It probably is a cap issue. Oddly enough, the caps look fine and there's no obvious leakage on the component side of the board, but there's a real mess on the underside of the board around each set of caps. I can't quite figure out how it got there. The board mounts with components facing down, so maybe the electrolyte evaporates and then condenses on the other side?
Juror22
I have one that is doing that and I took the easy way out. I replaced the mechanism with a working one from a donor.  Since I know that I am just putting off the inevitable, let us know if you come up with a more permanent solution.
