I got a 512k from a friend. He got it from someone, and that one completely took it apart. Also the case is painted with some ugly beige Apple Snow White wannabe color, that needs removing. Brake fluid prehaps?
The logic board is modded, there is a MagicSCSI card installed.
Analog board has two capacitors replaced with some 100uF 385V caps. They are much too big and also have quite high ESR (they are dated 21/90). What values were they originally? Locations C38 and C34.
Also there are CR22 and CR23 that were replaced sometime. The replacements are 1N4004, what were there originally?
There is also one clip broken on the anode cap. Will the CRT function without this clip, or should I get a replacement one somewhere?
I haven't powered it on as I would first try to repair any botched repairs.
