PowerBook 540c screen issue
crazyben
I recently acquired a PowerBook 540c. It boots up but the screen is having weird issue. It flickers between dark and bright and it has line all over making text unreadable. I did install 7.6 on it rule out the font issue for text. But nothing changed. Any idea what might be causing this? Do I need to recap it?
  • IMG_3973.mov
    35.9 MB
Shaddam IV
you might want o reset the screen cable (from the interconnect board to the screen). If this doesn't help, it might be the interconnect board... or even the motherboard.
crazyben
Reseting the cable didn't help. Now time to hunt the replacement parts.
Shaddam IV
I had a very similar issue on a Powerbook 165 (passive matrix screen). I tried resetting the cable and several interconnect boards. In the end the only thing that helped was a new motherboard. Good luck hunting!
Shaddam IV
I had understood that the active matrix color screens actually don't have a capacitor issue (only the passive matrix screens do).
alectrona2988
ahhhh. didn't know they made active matrix models before the 5300. the cable could be the issue given the line pattern, and the CCFL bulb is probably on its last legs with the flickering (or the inverter is faulty).
Shaddam IV
the 520s were passive matrix (520: greyscale, 520c: color); the 540s active matrix (540: greyscale, 540c: color). I'm looking to replace the CCFL of an 180 (active matrix), but I'd need to find out the voltage (I think this is a couple hundred V) and power consumption. Haven't done that yet. There are online shops that (still) sell CCFLs for such displays - mostly for medical devices.
crazyben
what is the best way to replace these? find another non working 540c?
alectrona2988
perhaps, yeah. screens for laptops this old can be super hard to find.... so you'd likely have to spring for a donor unit. or you can find the model of your panel and find the replacement panel for it, i suppose.
AEChadwick
AEChadwick
speaking of that... would it be possible to swap the screen on a 520 with a color active matrix screen?
yes, as long as you have the correct Interconnect-to-Display cable, you can have an Active Matrix PowerBook 520c
for the LQ94D041 Display you need the cable that says SHARP COLOR TFT (active matrix), part 821-0026-A / 632-0017-REV.A
everything else--inverter board, interconnect board, interconnect-to-inverter cable--is all the same & interchangeable.
3lectr1cPPC
My first guess would actually be a video issue on the logic board. It could absolutely be the screen though, so try a recap if it’s a Sharp display. If it’s a Toshiba, or if the recap doesn’t help, it’s gonna either be the screen itself or the logic board.
You also have two issues there - the flickering, and the missing columns of pixels. The latter looks far more like a cable problem. It’s just hard to know until you start swapping parts.
3lectr1cPPC
That sort of color flickering doesn’t look like it has to do with the backlight, I think that’s a video signal issue of some sort.
crazyben
I will take apart today to see what kind of display I have. Is this the right part for video cable?
alectrona2988
if you have a passive matrix display, yes. if yours is active matrix, no. the easiest way to tell is if your screen has more severe ghosting iirc, passive matrix refreshes slower and has a ghosting effect if you move something on screen (could be anything), active matrix is like what most LCD screens are, they refresh faster and don't have the weird fading thing.
3lectr1cPPC
That definitely appeared to be an active matrix screen. If it's a 540c, it almost certainly is. Someone COULD have swapped a 520c panel in, but that's extremely unlikely.
The screen in that unit should either be a Sharp LQ94D041, a Toshiba LTM09C017, or a Hosiden LCD without a model number (though those are rare). All three use different cables that aren't compatible with each other. Only the Sharp LCD has electrolytic caps on it.
