Still can't upload an image error-200
Dunno what the three GRID Signals are as yet, but all head from the A/B on the J3 connector to J5 on the GS Neck Board. Can't make heads or tails out of the Color30 Harness Schematic, so I combined its pinout data with the loopy harness illustration with its spatial relationship viewpoint. Illustration's all kinds of wonky as documented in a picture of a warped page at an angle.I guess you can't have everything, LOL! So I cleaned up in terms of which wire plugs more exactly where according to the schematic. Proofreading would be much appreciated.
Looks to me like the Color30 GS section is riding the MoBo's HSYNC as well as VSYNC mentioned in the docs. It passes the signals straight over to J2 on the AB.
Maverick may not need more than VSYNC as mentioned, but it pulls in and passes on HSYNC as well.
_____________________________________________________________________________________
Video Timing Generator:
Video timing signals are generated by counting through a series of mode
registers associated with the vertical and horizontal video waveforms. Please
refer to the attached drawing for a pictorial description of the timing elements.
The horizontal state machine cycles through each element twice per line to
allow for equalization pulse generation.
Most of the timing elements will be self-explanatory to those familiar with video
timing signals; however, there are some timing elements that are unique to the
Maverick design. The FS1 period is used to fill any pipeline that may exist
between the VRAM and the DAC. The FS2 period is used to empty the pipeline.
NS defines the period where bus access to the DAC will not interfere with the
generation of video. HS22 is used for the generation of equalization pulses
only.
Interlaced and noninterlaced video formats are supported. Vertical state
transitions may be made at half-line or whole- line boundaries. Equalization
pulses in the vertical blanking signal may be enabled or disabled. Display
sizes up to 2K x 2K are supported. Vertical sync and field ID may be generated
externally or internally. For external vertical sync Maverick will wait for an
external sync pulse at each vertical front porch period. The falling edge of the
active low external sync will force the vertical timing state machine to go into the
internal vertical sync state. NTSC timing waveforms are generated by putting
the video timing in interlaced mode, selecting the proper horizontal and vertical
resolutions, using half line counts in the vertical state machine, and turning on
the equalization pulses.
Gut call (Ludicrous WAG) is that much of the 306-48 schematic will need to be excised and adapted for VSYNC and HSYNC driving the timings. I wonder if the 306-GS clone (or the Color30) really needs an oscillator while operating in GS mode? Every clock in the book is available for reference on the PDS with VSYNC and HSYNC available on the MoBo's A/B connector. Video goes straight through to the A/B unmolested and exits the other side where it's picked up by the Color30 for passing on to the Neck Board when in external monitor detected mode.
Dunno, I just make pretty pictures. [
