I am also under the impression that the BIOS is what is restricting IDT and AMD chips from running on these cards. There doesn't seem to be a way to get into the BIOS from the software though. The Apple cards inject the BIOS at startup time from the resource fork (similar to how all but the very earliest and latest OrangePC cards worked). Opening the "PC Setup" control panel in ResEdit shows the BIOS. I'm not familiar enough with classic Mac OS development to know how to copy it out, modify it, then replace it. Patching the BIOS should absolutely be possible though. As for cache, the Apple cards (P100 and P166) have 256k of 15ns L2 cache built into the card. The cache shows up on the BIOS boot screen, but HWiNFO and CPU-Z can't see it. The cache does show up and is working with cachechk and speedsys though.Thanks for sharing your project. The limitation on other CPUs is probably software. Can you get to the BIOS? With BIOS patches and voltage adapters even the oldest socket 5 PCs can run AMD CPUs. The "plus" versions have L2 cache built into the CPU that can make a huge difference in performance. Does the apple card have any external cache?
