Macintosh 68060 Redux
Thanks! I took styling hints from the IIcx to the point where I was even measuring features with calipers. The "minor" lines on the front hide the primary vents, there are secondary vents in the vicinity of the picoPSU as well as the 060/cache board to draw air over the heatsink. I hadn't thought about setting up for an external floppy (actually, floppy never crossed my mind at all...), but I have plenty of space on the rear panel so I might do that...
@zigzagjoe What app do you use for modeling? I've often toyed with the idea of reproducing some of Frog Design's prototypes and making them into real products. There's a guy on YouTube who did that with Apple's really slick MessagePad/Phone combo unit. Another guy (same guy?) did it with the Apple //c prototype.
Autodesk fusion. While I'm not in love with being in bed with autodesk, I learned autodesk inventor around 20 years ago and that's how my brain works when thinking about these things now. It's not the easiest thing to do aesthetically pleasing stuff in, I'd say, but great for engineering tasks.
Last time I used AutoDesk was AutoDesk R12 on Windows 3. I have free access to their online version through my education account, but I found it very confusing.
FreeCAD, https://www.freecad.org/, is otherwise open source and powerful. It is fully offline. Personally I also use Fusion 360, but I'm not super keen on the cloud based nature of it. Fusion is a lot more forgiving compared to FreeCAD (in Fusion sketches does not need to have all constraints fulfilled for instance).
Others have also used TInkercad with great success (never personally tried it).
Yeah, FreeCAD is a little odd if you're used to some of the commercial offerings, but is plenty good enough.
Make sure you get version 1.1 as it includes some good quality of life improvements. (Or newer if you read this in the future when later versions exist, unless newer versions get worse, in which case stick to 1.1).
I've been trying to develop my FreeCAD skills lately.
Finally got around to putting a LA on the machine to chase the network issue, and the problem became obvious. Turns out, if it walks like a duck (data corruption), talks like a duck (data corruption): it's probably a duck (data corruption).
The SONIC (+BIOS) and 060 are fighting over the bus. Specifically, the 060 took the bus when it shouldn't have; the SONIC continues to try to run cycles as it's the rightful owner of the bus at the same time as the CPU, and everything goes awry. Fall down, go boom.
Wouldn't you know it, there's an errata that sounds a heck of a lot like this. As the SONIC takes a moment before running the first bus cycle, as far as my buggy early 060 is concerned it never sent one at all.
The solution is straightforward: the third workaround, don't issue BG to the 060 until we see BB go high first indicating the SONIC is off the bus. My adapter picks up three more bodges.
And just like that, no more crashing. I haven't tried Appletalk over IP yet but I expect it's working too.
Takeaway: if using the "simple" 060 adapters, you must use a late mask 060 for the onboard networking to work. Otherwise, the onboard networking can't be used. A nubus card could be used instead, though it's about half as fast as the onboard. This has some relevance to other Macs which might potentially host an 060: no bus mastering PDS or Nubus cards can be used with early mask chips. In particular, the LC475/605 would need to be wary of the later LC PDS ethernet cards which use a bus mastering SONIC.
Takeaway: if using the "simple" 060 adapters, you must use a late mask full 060 ("rev 6" 0E41J) or a LC chip for the onboard networking to work. Otherwise, the onboard networking can't be used. A nubus card could be used instead, though it's about half as fast as the onboard. This has some relevance to other Macs which might potentially host an 060: no bus mastering PDS or Nubus cards can be used with early mask chips. In particular, the LC475/605 would need to be wary of the later LC PDS ethernet cards which use a bus mastering SONIC.
Interesting.
You mentioned not mattering with an LC 060? Is that just because the LCs all don't have the bug? Were they all a later mask?
Interesting.
Exactly. I attached the errata document to the prior post for reading, but here's the relevant bit.
Those early 060s were buggy sumbitches. Even if motorola had delivered them on time, the existing macintosh chipsets would have needed to be changed (or, more likely, a patch GAL added) in order to avoid this.
Am I reading that table wrong? What if you have a 1F43G mask 68LC060? Don't you have the bug then?
Uh, nope, you're right; I don't know why I entirely missed the LC chips listed too. D'oh. Thankfully, we're within the edit window :)
Shame though, it means an LC chip isn't an easy work around (let's be honest, full fat 060s aren't exactly affordable anyway!).
Last i checked the later LC chips are still around a third of the price of an early (buggy) full 060. So, definitely more palatable!
Ultimately, I still regard this as a curio: 060 is impractical for Mac use unless someone is willing to put in the major work required to fix the corner cases and round off some of the edges. You're really better grabbing a reasonably spritely PPC. I'm not sure that anyone else has gotten around to booting an 060 yet - not that I've heard, anyways.
Yeah, I don't have a programmable ROM or the ROM hacking experience.
Truthfully I see the LC 475 as the exception to the not worth it rule because those LC socket PPC cards aren't affordable, and the bus doubling feature, combined with the 475s programmable bus, opens the door to 75MHz 475's even without exceedingthe logic board or CPU ratings.
I'm hopeful we'll see progress with time, or I'll ne day I'll learn enough :)
Notably, the VRAM-based framebuffers in the LC475 and 650 seem much faster in most QD operations (~2x) compared to the early PPCs except in operations where the 64 bit memory bus comes into plays (basically, copybits). According to the canned benchmarks shipped with System Info. I wonder how they compare to the HPV cards.
I think the sanest path forward would be trying to take the supermario source and backport it, figuring out what they broke by accident for the earlier platforms. This would at least ensure good hygiene from the ROM perspective, though the issues with later versions of Mac OS would remain. The architecture of Mac OS does no favors here. I expect a need for some compatibility help for old code - think like the control panels shipped with early 040 products.
An oddity with that - my Nubus PPCs never match the performance of the canned benchmark results, I forget in which scores, but I never got to the bottom of it. I always try to compare with my own machines for those models because of it.
Real machines were slower, even with a clean install.
The HPV scores higher than the AV card, as does the RAM based built in video! I forget by now much.
I did forget that System info doesn't control for resolution in their benchmarks, so I didn't verify the powermacs were running 1:1 resolution. That'd be an unfair comparison, if so.
I've validated the bus arbitration fix to be stable and it's addressed the issue with the SONIC. With the 060 (and a modern networking stack...) netbsd can more or less saturate the 10MB half duplex connection with 7-8mbits of TCP or 9mbits of UDP traffic. The only change I made to NetBSD was to change SONIC_NTXDESC/SONIC_NRXDESC from 32 to 128 buffers, as the SONIC would continually run out of buffers otherwise which had a potential for occasional interface hangs.
Now I'm working on getting some packages built as the publicly posted pkgsrc is woefully (and oddly) incomplete. I tried cross-compiling, but this approach is not viable, so instead I'm building packages in a QEMU VM... slow, but it's still about 10x faster than the 75mhz 060.
Other misc findings on the Mac side:
Localtalk silently fails above 33mhz (bus). Probably a timing issue. Seemed OK at 33mhz but I did not strenuously test.
Quicktake does not work at all, unable to establish communications with the camera.
PC Exchange is unable to mount dos volumes - might be a 7.1 thing
Quickcam Color works perfectly at 37.5mhz (bus, w/cache). This proves the serial hardware itself is fine, along with NetBSD.
Appletalk over ethernet works, but is unable to be enabled in the network control panel - system hangs, generally - it must be set in PRAM prior to boot.
Quicktime 2+ tends to cause F-line exceptions during boot, but not consistently.
Apple Multiple Scan Display Software allows 7.1 to recognize multisync monitors (+adapters) and change resolution on the fly. Updates Monitors CDEV to 7.5.
Quicktake issue and Localtalk are both timing related issues. Localtalk will not work from 35.5 to 37.5mhz bus speeds - but those same speeds are fine on an 040, as are higher speeds. Quicktake doesn't work at all. However, turning off Branch Cache on the 060 allows these to work though at a significant cost to speed elsewhere. My assumption is for both a timing loop to synchronize to serial traffic is being accelerated to a point where whatever calibration routine exists is failing to adapt.
This ties back into the need for something to deal with compatibility foibes - if 060 in mac is ever to become realistic. Of course, there's bigger issues to be addressed first. I might make a quick GUI for personal use, but something that can toggle CPU features according to what's running would probably be needed.
