There’s enough gap to need some wireIf there isn't actually a break, all you need to do is tin them to add some material and protect them.
Oh yes you mean the iffy ones. Yes I’ll scrape then clean and coat with solder and UV mask them.There’s enough gap to need some wire
I use the probes too like that. But some are so bad they need careful scraping.What @Phipli said. I just scrape the dark parts with the meter probe, and tin over - using an x-acto feels a bit aggro. Wire only goes over confirmed breaks. UV mask is a thing I usually skip as I find it usually just makes things uglier (it's only really needed in certain things).
I also have a fiberglass pen. Those work great too.I use the probes too like that. But some are so bad they need careful scraping.
Uf13Pin 32 of what, exactly?
Ah that's far off from where we're looking. It's SCC B transmit clock. 4MHz-ish sounds right.Uf13
Yeah I figured after checking schematicsAh that's far off from where we're looking. It's SCC B transmit clock. 4MHz-ish sounds right.
Uc9 pin 3 - highCheck pin 3 on those same ICs. However something's odd. All address lines generated by NuChip are quiet, but you're telling me those coming from the system side are asserted, or at least something is forcing them on.
Check UDs as well, feel free to check both A and B sides. I have a suspicion this might be close to the issue, especially considering how bad traces around that area look.
No, it doesn't mean anything - somewhere earlier I mentioned broken silicon may still act in ways that seem sensible. While reset is asserted, the system is in undefined state. What reset does is clear the slate and get it all into a known default state the machine can start running from. That would include throwing the CPU at its reset vector, what on the m68kis called an IISR, which makes it go to the bottom of the address space (0x00000000) and then start executing from 0x04. As you can imagine, that location is physically pointed at by an all-low address lines combined.On it. So when I hit reset, the address lines on the roms go high and then back to low. Does this mean the CPU is not “dead” ?
Earlier production IIcx boards have socketed CPUs, later ones do not. Same for the SE/30.I seemed to recall those being socketed.
