SE/30 Reloaded - Wrong clock frequencies on everything; no C16M from GLUE
Boctor
I've seen similar issues to this reported by other people, all of which were usually solved by cleaning and reflowing, but I've now tried so many times that I'm completely stumped and would appreciate expert advice on what to try next. I have a mostly-built SE/30 Reloaded, using this PCB, with all of the surface mounted components installed. All of the array logic is also installed. The only ICs I skipped were the Bourns filters. These chips were all working pulls from an SE/30 that worked reliably 3 months ago, but started developing some issues with trace rot from residual corrosion. I didn't want to deal with electrolyte wicking down vias or anything in the future, since it was not originally my machine, and I am frankly not cut out for 6-layer PCB repair.
Since I'm trying to get a minimally working system that walks the bus, or ideally blares some "no RAM" death chimes, I have not installed any connectors except for the speaker pins, the power/video socket, the PLCC ROM sockets, the CPU/socket and the battery holder. Unfortunately, all that seems to work are the reset circuit and the video PALs with a stable NEC Simasimac pattern. Nothing gets particularly hot and I can't find shorts to ground anywhere obvious. I've been reflowing things that don't look perfect, while checking pairs of adjacent pins for continuity without anything beeping at me. (Well, except 1, 6, 10 and 11 on UH7, but those are all ground!)
Somehow, the clocks are all over the place. I see something like 24Mhz from Y2 sometimes, but it's never anywhere near 31.3344. The 16Mhz clock generated from GLUE using this is absent. The scope shows the waveforms from Y2's pin shaking violently, too. When I put in a battery with the board off and probe Y1, I see the perfect, intended 32,768hz from the RTC. However, when I power the board up from DC, it's complete havoc. The reset circuit goes from 0V to 5V as it should, every chip connected and showing the same voltages, but the clocks from Y1/Y2/Y3 are all over the place, and the waveforms on the scope bounce up and down violently. Have I shorted something obvious and polluted my clock signals? I'm probing the legs of the oscillators/crystals themselves, so it really feels symptomatic of a short somewhere, but nothing's jumping out at me. Maybe there's some residue from flux/washing stuck between the legs of the CPU socket? I'm just unsure how it could have this sort of an effect. Especially since I have an old junk board with its CPU removed that does approximately the same thing when powered up.
The AB is recapped and reflowed and works great, the power supply is a modular Meanwell replacement with good +5/+12/-12 every time I probe it, and I've checked the voltages on everything thoroughly. The Sony chip putting RESET at +5V implies the voltages stabilize within what the hardware expects. I do not have a working SE/30 board to test with, but this Mac was originally an SE, and my SE board works fantastically in it with no transient issues. Something on the board has to be the X factor.
Which wouldn’t be there if you didn’t have a proper 16MHz clock. What are you using to measure the clock signals? The outputs of the crystals themselves can actually be interfered by your probes.
Are you sure the board isn’t doing the no RAM chime? You need the headphone connector to be installed for the internal speaker connector to work (unless you closed the two solder jumpers at the bottom of the board near the headphone port)
Thanks for reminding me about those jumper pads. I saw them on the first day of assembly, then quickly forgot about their purpose. I still do not hear the speaker pop when turning on, nor any kind of chime. My ROMs are the PLCCs with the properly byte-reversed bins from your repo, the V-labeled sections of the triplet pads on either side are jumped with solder. The first three ROMS are proper SST39SF010 chips, but the fourth chip is an AT49F512 taken from something else, which I imagine is not going to work at all. It's unfortunately all I had on hand, as I have to wait until next week for more SST39s.
My scope is a cheap one, a FNIRSI 2C53T. I'd been using a cheap multimeter to try and poll frequencies up to this point. I set the scope for 5V DC, X10 sensitivity on the probe and the unit, and autotrigger with the rise of the waveform, but I assume since I'm so new to this, there's still foundational electronics knowledge here that I'm missing... And just while typing this, I checked out how this scope is supposed to be connected, and it's a huge step up from the old one I had, which would never have worked, since it couldn't be properly grounded.
Securing the ground of the probe onto the negative leg of the axial filter cap for the 5V line, I probed the RTC and GLUE clock pins once more, and I saw the requisite 15.67Mhz and 31.334Mhz coming from GLUE's 17th and 18th pins. The "Simasima" PDF guide claims ~15.72 is expected for C16G, not 15.67 which is C16M instead, but it seems like this signal is just repeating through UI6, from what you and others have said? The values in that guide are sometimes approximate, hence '~', but I want to be extra careful here.
The CPU has a clock signal as well, so maybe I should remove all of the flash ROM chips and see if I can ensure it's walking the bus. The PDS slot breaks out every address/data line, right? I'm trying to visualize how this is going to work, and what kinds of signals I should expect per pin.
(Given the false-positive from not having a proper scope, I wish I could re-title this thread to something more appropriate, so as not to bother people searching for that issue. I know at least one other person was having issues getting the 16 and 32Mhz clocks from GLUE, so it is a real phenomenon.)
To remove further possibilities of my own mistakes, I've cleanly and carefully removed the PLCC sockets, un-jumped the ROM pads back to all open, and installed a good SIMM64 slot cleaned off of a junk board. I still have the "speaker" jumpers both jumped, but do not hear anything from the speaker. (If I recall, the "pop" before the chime is still something that'd require the CPU to be executing things from the ROM, but it's been quite a while since I had a working SE/30 board to know for sure.)
My 3/16/32 and E clock all look fine. Unfortunately, ROMN on GLUE stays high. I am having difficulty finding the correct frequencies in the ROM slot that indicate the CPU is walking the bus, yet it's also not stuck in reset, so I'm not entirely sure what it is doing. It has power and the correct clock frequency, however.
Could this be an issue related to muxes, or just something simple like a short under a chip pulling a line hi/lo that shouldn't be? I'd appreciate if an expert who has seen this before could give me a kick in the right direction, or point out an obvious thing I've missed, since I have a habit of doing that. In the meantime, I'll keep researching if anyone's come across this before.
At the time of writing, the "Simasima" PDF guide I was using to troubleshoot lists incorrect address bus frequencies. I also did not realize that the processor eventually stopped walking the bus (I think) after enough time has passed, hence why I was not seeing anything on the address lines when leaving the board idle for too long. People here have mentioned this before: A2, which is also broken out as ROM pin 4, is supposed to start at 1.3Mhz, dividing down by two for every subsequent pin. I do have all the right frequencies on the first several address lines from A2, when a ROM is not inserted. My CPU is alive and walking the bus. I have 5V on /HALT, /BERR, /AS, /IPL0-2, /BGACK, and /BR. I measured /BG out of curiosity and it reads 3.84V. Unfortunately, even with all the false-positives, I still seem to be unable to read ROMs. On the data pins I've seen people probe, I can't find activity. I get 5V on ROMN every time I boot with anything inserted, and am wondering if a data/address line somewhere is broken. (I'm even curious if I damaged a trace somewhere, but this has to be my OCD speaking.)
I swapped GLUE for my only spare, using only the required amount of flux from a pen, so it couldn't ooze underneath the chip while working. I probed every adjacent set of pins including corners before powering on, to eliminate the possibility of shorting it and frying it. Within my means, a bad GLUE has been ruled out. It behaves identically to the other one. Here's my latest board photo, in case I've overlooked something obvious that's required to boot, or installed something backwards:
I'm starting to wonder if this is something smaller, or if JLPCB accidentally used a wrong passive somewhere. Other people who have boards from this batch have not yet shared any completed builds, so it's difficult to say. As always, if anyone has tips, I would appreciate any information! I'm going to take a break and return to lurking the hacks/development threads.
This is all a bit surreal. I still need to pop a SCSI header and an ADB port in here to check it out a bit further, but I am very pleased at how much sense this made, in the middle of a seemingly impossible puzzle. I did reason pretty quickly that the bus walk and lack of data transfer meant "something" was wrong with the data bus, but I needed to sleep on that before approaching it again.
Human error, once again: It turns out that I didn't hold the probes long enough when checking the FPU for shorts, and the FPU is a chip where D23 and Vcc are adjacent. D23 was always high, and when toning out the ROM slot again to make sure the buses weren't swizzled, the +5V line and pin 54 beeped, which alerted me pretty quickly. Also of note, D23 is not used on places like the video/audio circuitry. I bridged these same pins in my IIcx with a small screwdriver to ensure the line being stuck high was doing what I thought it did. The ROMN pin was completely a red herring, the frequency tables in the "Simasima" PDF guide are currently wrong for a bus walk (As Techknight's one video shows, you begin with 1.3, not 2.6) and toning out the SIMM slot is an excellent breakout of the A/D lines of the bus, if you want to not only check continuity but also detect shorts. This post was vital in reminding me of that.
I was immediately getting the intended death chimes after I removed the short via a tacky reflow, wicking excess, and a bit of wiping up. Anything else I speculated is ruled out. It was one silver bullet, but a really well-hidden one. GLUE seems to be doing all it should, passives are working, TTL chips are multiplexing the bus. If you bought a PCB from this batch and the diodes have the right silkscreen on them, which I don't see why they wouldn't, then your passives are probably A-OK.
I'll only declare this a complete success once I get the ADB/SCSI/Serial figured out, and PDS would be the icing on the cake if I can make it that far with a bit of patience. Again, apologies for the thread title. If it's okay to ask for it to be changed to something more general or appropriate to aid future people searching for issues, I would very much appreciate that. And thanks again to Bolle for pointing out the clock already being used for the picture display. Without stopping for a minute to think more critically about that, I wouldn't even have bought an oscilloscope to hunt down this little short. I'm always relieved when a mistake is my fault and not a ruined component. It's better to get a little more experience every time than to give up over lack of quick gratification.
This thread's turning into more of a build log, with the only fault removed.
Finished putting the rest of the components on and cleaning residue. Not going to install the buttons despite having them, since they're salvaged and have some kind of dried up glue on them, and I don't have the right solvents to deep clean them. I don't even own the external clip-ins anyway. Same for the RAM slots: If I can do 16 or 32 megs I'm happy. I use the vanilla ROM, so I like to have the memtest, but not wait an excessively long time, and that extra room on the PCB is sure helpful for cleaning and maintenance.
I tried out the PDS with my RasterOps card, and was overjoyed that it worked again. This was the card that suddenly stopped the old one from booting, alerting me that the original board was probably suffering from vias or internal traces going bad due to latent corrosion. The reloading might seem overkill, but I never want to deal with blind vias and hidden logic layers again, six-layer is the pits. I was not even the person who did the original recap on the original board, either. (Judging from the smells while salvaging the components, they wiped it with alcohol but didn't bother actually washing it. No ultrasonic, soap and warm water with distilled bath, white vinegar, lifting ICs for a manual deep clean, isopropyl immersion bath. Nothing.) I neutralized everything from the old board pretty aggressively before bathing it in isopropyl, despite only maybe two or three things being anywhere near the hidden fish stink, just to be thorough and rule out any future problems. No crust or green oxides anywhere, though, so the chips themselves were never in doubt, just the old PCB.
Not pictured, but I finished putting it all back in the case once I installed the support bracket. I didn't end up installing ColorBoard for the time being (I don't want a phantom monitor whenever I don't have a second one handy.) The TwinSpark is similarly kind of a waste at the moment, since my DiiMO is in the IIci, where I think it's more appropriate. I'd love to get a Socket Booster or similar, if any more are ever built and offered for sale.
