At least it doesn't use any BGA stuff!The SE/30 is probably the one most in need of a new PCB though it is more complex than the basic SE and would require a lot of SMD skills but who knows. Maybe with the right stencil, paste, and reflow oven it can be streamlined.
Definitely seconded 10,000%!!!Amazing, love your work!
That would be interesting. While you're at it, rework the power supply circuitry so it can run without a battery, if need be, and have the redesign be implement-able on an otherwise stock Portable LB (for those fortunate enough to have one that by some miracle still works).< tangent >
But for the SE/30 project, I think we need to make a few upgrades and provision for a bit of modularity. @maceffects with a noodge here and a cutaway section there, an SE/30 board will fit in an unmodified Portable case ... Without doing the cutaway hacking, it'll still fit and look hella fine in your clear case. ...
< /tangent >
"need" is a strong word hereBut for the SE/30 project, I think we need to make a few upgrades and provision for a bit of modularity
Ha! The idea of a completely non-Apple SE/30 is great. Let's keep our SE/30s running indefinitely...Another vote for the SE/30 next! I have two SE/30s that I shoddily recapped, and the boards aren't in the greatest condition, so now that I have better soldering skills, I'd love to give my two SE/30s fresh boards, with all non-proprietary/unobtanium ICs and components replaced with fresh ones. Ensuring I'll never add leakage prone batteries and capacitors, those boards will likely outlast the originals!
You're forgetting the proprietary Silicon on the board, very Apple that.... all you need to do then is create your own internal chassis and boom – a completely non-Apple SE/30!
We've already got a cleaned up version of Apple's schematic ready for mucking about a bit from a ground up build. Has it been checked against the Bomarc schematic? I need to get at least the memory page of that version."need" is a strong word hereI'd suspect it would be a lot easier to muck around with the board after the event if you know you're starting from a working layout and schematic.
Thinking PicoPSU/Plugged in only at first. After that a 24v battery pack that would match the three hour battery life of the MacColby SE30 might be possible?That would be interesting. While you're at it, rework the power supply circuitry so it can run without a battery, if need be, and have the redesign be implement-able on an otherwise stock Portable LB (for those fortunate enough to have one that by some miracle still works).< tangent >
< /tangent >
I have one of these I'm quite happy to drop into the post for you.Someone needs to send me two or three dead SE/30 boards
Curious about this, tooHow are you going to scan the internal signal layers on the SE/30 logicboard for a 1:1 repro?
This is really awesome. I'll be looking forward to seeing the first repro SE board booted up!
The SE/30 has more custom logic, no? Is it possible to program another chip with the VLSI code? Or would some modern replacement need to be made?
RE LCDs: While this is probably the only way to keep these operating in the long run, I think using the CRT is part of the charm of these machines, is it not?
