Macintosh SE/30 M5119 - Restoration
The Pin Matrix Data chart insists pin N is the last pin of UK8, the CPU. The Pin Matrix chart lines up correctly if you ignore there are only (13) pins, and pretend the last one is N.
At least I didn't make it any worse.
Need to check the Reset and Clock lines today.
Is there a way to check the ROM without a spare or replacement?
Rather than try to visually inspect this board for broken traces, it's time for a diagnostics program.
In this episode of Adrian's Digital Basement: he uses a modem cable (8-pin to 25-pin), converted with Laplink cables, to connect to a PC's DB9 port with Terra Term - in order to obtain error codes for a pre-ROM boot (simasimac SE/30 board).
With the Poor-Man's Tech Step, he's able to decipher the error code, and locate the broken chip/trace with the info obtained.
Rather than going through all those conversions of cable's, would it be possible to use just an 8-pin DIN, that goes straight to DB9, such as this cable?
I have plenty of good DB9 capable PC's here. Just can't determine if that 8-pin Apple printer cable would line up with the correct DB9 output, or RS-232 COM port input. A null modem adapter might be necessary to cross the Tx and Rx between terminals, in order to get that to work.
I can confirm this works. I believe Apple printer cables are nulled by default. I used one to connect my Macintosh Plus with Zterm to my IIfx to access the diagnostics mode a few years ago.
The problem that I had wasn’t the connection— there is virtually no documentation that I could find on the actual diagnostics commands and the responses. Apparently different ROMs have somewhat different command and reply sets. I could never make much sense of what information I was getting.
But, it does work.
Sorry, I should have been more clear: DIN8 to DIN8 printer cables work. Plus and IIfx both use DIN8 serial ports.
Thanks for that document regarding the diagnostics. It’s probably time I tried it again, as my IIfx still does not live.
I’ve done the poor man’s tech step on my SE/30 using DB9 to DIN-8 cable I made for use with ADTPro on my Apple IIGS. Here is the pinout:
It’s wired as a null modem. I used an old DIN8 to DIN8 cable, cut one end off and attached a DB9 breakout board:
Nice work! What are you using on the DB9 end to talk to the SE/30 board with? Have you been able to retrieve any useful info from it?
I was running CoolTerm on a 2018 mac mini running macOS Sequoia
Using this USB to DB9 adapter - I like it because its 6ft long, so between the adatper and the null modem cable I could have the SE/30 on bench across room
I see its no longer for sale, but other 6ft adapters exist.
I was able to execute code on the CPU using TechStep commands - that made me focus on video circuit, it ended up being UG8. I wrote about my troubleshooting here: https://68kmla.org/bb/index.php?thr...king-to-no-video-does-chime-on-startup.48851/
This is probably a very good candidate for a reloaded board. Caymac?
I've got to try to fix this stock board, if all else fails the Reloaded board is a great option.
Gives me some hope this can be a useful tool. Thanks.
It took forever to get that din-8 to DB9 cable from ebay.
When I connect it between a PC/USB COM port and the SE/30 serial port next to the audio output jack, I get no flashing cursor or keyboard input in Putty or TeraTerm, both set to 9600, 8, 2 stop bits, no parity, no flow control. Have a null modem adapter on the way tomorrow, to see if this is what the problem is and why I get no cursor.
Not all DIN-8 to DB9 adapters are created equal; some contain the minimal pins and logic to print to a dot matrix printer and don't handle other hardware. Had this issue years back trying to get a hardware dongle to work.
