Ok yeah so the cpu seems to be “not dead” hah"The processor also halts if it receives a bus error or address error during the vector table read operations or the prefetch for the first instruction after an external reset. STATUS remains asserted until the processor is reset."
Ha I may have to drag the logic analyzer out.Doesn't seem dead, no. At least we know it's trying to fetch from memory. Would be good to see captures upon reset of the first few address lines, and maybe a couple few datalines too. We have to establish what is causing it to fail to fetch from the reset vector
The ROM sockets. Clip onto ROM chip pins, or plug a turned pin male header (small pins that don't bend the contacts) into the empty sockets.Ha I may have to drag the logic analyzer out.
I need some way to clip onto the pins.
My current options are janky….
Right. That’ll work. I have clips.The ROM sockets. Clip onto ROM chip pins, or plug a turned pin male header (small pins that don't bend the contacts) into the empty sockets.
