Well, baby steps. At this point, we've got a driver that is naively overwriting the floppy driver to get loaded, and the whole CrsrTask thing is still an unknown (at least it has a workaround though...). It would be good to get it loading without overwriting the floppy driver, and then that'd be a much cleaner way of adding the driver to the ROM. But, that's a good bit of work and far less sexy than slapping a driver into the ROM, yet at the same time opens more options for future ROM expansion.
So, we'll see. If anyone else wants to start hacking, let me know and I'll set you up.
DeclROM hacking is definitely interesting and on the TODO, but we've got a long way to go before exhausting the potential of dougg3's ROM SIMM!
MMU hackery is also on the TODO, as it would be nice to get the full 2MB of the ROM SIMM mapped in at boot time, although that seems like it might require System changes as well. The ROM initializes the MMU and sets up some mappings. The System software then reinitializes all that and sets up mappings the way it wants. Which is why my initial attempts to use 0x40880000 worked in ROM before System boot and after System boot, but not if a read operation came in during boot when the mappings were changing. And also why some System software has more or less ROM mapped in than others. So if we muck with the mappings from the ROM, it gets us access to that space pre-boot, but not during & after boot. For post-boot stuff, the possibilities are much easier since things are not changing as much, but at that point you don't really need to be doing ROM hacking, just throw it all in an INIT.
And then there's time. The ROMDriver was a wonderful coincidence in that I already had written the memory disk driver, so that was easily modified, and dougg3's SIMM arrived right before a holiday, so time was available. I expect my personal contributions to come at a much slower pace in the future. And the TODO list runneth over, as you can see.
On a related note, when I was working on a ROM patcher for the disk driver last night, I noticed the II/IIx ROMs had a pretty significantly different resource layout than the IIsi/IIci ROMs. The IIsi/IIci version seemed to be a much more compact representation, but it's a different way of locating the DRVR resource. I'm thinking of doing a naive check of if the ROM size is <512k, go with the II/IIx way of locating the driver, otherwise, go with the IIsi/IIci method. Checking the checksum or machine id's or anything else in the ROM isn't going to be very reliable since we're all about modifying the ROM now.
I checked the Basilisk II source, and they're using the IIsi/IIci method of locating resources. I don't think Basilisk II will work with the II/IIx ROMs...
