Punkyclown
Hi All, since I am struggling mightily to get software to run on my powerbook 1400c, the
question arises. Which version of Mac OS should I be running on my Mac? The System is
a PowerPC 603e running at 117mhz, it has 32mgs of ram installed and Virtual ram is set
at 32mgs. I am using a 1 gig hard drive, I am currently running Mac OS 9.1. A lot of the
software I am trying to use requires MacTCP, only OS 9.1 doesn't use it, it uses MacTCP DNR.
This is obviously not the same thing. So I am open to suggestions as to what OS would be
best for my set up?
Thanks in advance for the advice
Brad Hansen
best for my set up?
Brad Hansen
