Depends on how fast the SCSI drive is. A 7200rpm drive will improve the drive performance and would be a lot cheaper than the SCSI card and hard disk. Around Raleigh NC an 80GB drive retail is about $50.Right now it has a old 5400 rpm harddrive, what will be faster: new 7200 rpm HD or a SCSI card with scsi HD ?
Bert
I assume it's the rev. 2 because it has three drive tray's on the bottom of the case. Guess i'll just get a new 7200 rpm hard drive then.well seeing a B&W comes standard with a IDE HDD you might want to stick with that.
not saying a scsi HDD is slow (cause they are not)
BTW what rev is that B&W
well he could plunk in a G4 cpu upgrade but that would be the same thing reallyI wouldn't change over an IDE Mac to SCSI. The drives are usually more expensive and in smaller capacities. To gain some speed but lose capacity for more money isn't a good trade off IMO.
It's not really worth upgrading a B&W to modern standards at all if you want to take it that far. You can buy a newer Mac with higher specs and better expandability options for less money than you would spend on upgrades. A 1.6ghz G5 costs less than some G4 upgrades now.well he could plunk in a G4 cpu upgrade but that would be the same thing reallyI wouldn't change over an IDE Mac to SCSI. The drives are usually more expensive and in smaller capacities. To gain some speed but lose capacity for more money isn't a good trade off IMO.
the best things he can do is max out the ram ( 1,5 gig ) or at least more ram
turn off dashboard and spotlight
get a better video card
and thats it
or take all that upgrade to a faster G4
think of what you will spend on all that and look in to a used G4 mini
unless off course he likes to have a blue yikes!
Unless I am mistaken if the G4 upgrade is past something like 500 or 600Mhz the bus has to be run at 66Mhz or something. G3s should be able to run high with no bus speed reduction. I think they make 1.1Ghz versions of both...well he could plunk in a G4 cpu upgrade but that would be the same thing really
Blue&Whites can take a max of 1GB (256MB per slot) if I recall from the Rev 1 and Rev 2 that I own.the best things he can do is max out the ram ( 1,5 gig ) or at least more ram
An original Radeon or Radeon 7000 is cheap.(try not to get a 7000 though, they are shit)There are other more expensive cards like the 9200 and I think some 5x00 series nvidia but those can get expensive.get a better video card
Yes, with all G3 CPUs of any speed and G4 upgrades less than 700Mhz.http://www.ehmac.ca/anything-mac/46292-larger-yikes-g4-heatsink-4-clip-version-b-w-g3-2.html#post474740and it s not really about the speed of the machine the blue G3's have a 100 mhz bus
Yes, I would very much recommend the 500 MHz G4 - I got one for my Beigey and it's awesome, so fast and now runs all the AltiVec stuff like iLife '08. They can sometimes go for crazy prices though, which they are not worth as you can buy a real Sawtooth for that kind of cash these days and run Leopard - I only paid £3.20 including postage for mine, which is still more than my whole Mac is worth!Though, even a 500Mhz G4 or even 600Mhz G3 would help considerably over the stock CPU.
