JDW
Well, I fixed the PCB trace that had been rated by leaked fluid (in the vicinity of the battery). Unfortunately, I get the same exact response -- horizontal lines and a sad Mac chime, both exactly as they were before (and as they appear and sound in my video). So obviously, this is not the only broken trace and/or there could be a bad chip on the board.
I spent a lot of time last night checking points with the aid of my schematic. I checked all the pins on UK6 (video ROM), D0-31 (Data pins) leading from the ROM to the RAM SIMMs and to D4 - D19, I reverified that pin 45 of the ROM (Address A22) properly connected to all the points I could find on my schematics (proving my fix was good). So far, I've not found anything else bad, but there are hundreds of other places that would need to be checked, and even then one cannot know if a chip is bad. Further, I am still concerned about resurrecting vias in light of this being a multi-layered board. I could easily spend another 5-10 hours checking points and still may not come up with a remedy. I just don't have 5-10 hours or the desire to commit so much time. I will keep testing the board when I have spare time, as I am not to not sleep well at night until a problem is solved. But I must admit I am rather frustrated with this board.
Had I another socketed board, I would be content with just putting this board out of its misery. But I wanted to test the Daystar accelerator in another socketed motherboard to see if that resolved the lock-up problem I had with it. I did test the CPU of the Daystar accelerator last night. I pulled the 68030 chip from the Daystar board and put it into my known-good socketed SE/30 logic board, then I fired up the machine and ran Norton System Info (benchmark utility), followed by running extensive Norton Disk Utility tests on my 4.5GB hard drive's 3 partitions -- all of which put a good deal of stress on RAM, CPU and Disk. I left the machine on all last night (with screen brightness turned down to avoid burn-in), and the machine never locked up once. I then used it a little while this morning and it worked fine. So the CPU of the Daystar upgrade is not the reason why that upgrade is locking up. That's a fact.
