jckarter
Hi everyone! I recently got my hands on a Micron Xceed Color 30 board. The manual mentioned that it supported the Portrait Display, so I thought I'd give it a shot, but it seems to be detecting the monitor as a regular 640x480 display and driving it with landscape timings, which gives some glitched output, with the left and right halves of the image swapped and overlapping each other as shown in this photo. I can find my way to the monitor control panel in System 7.5, but it doesn't appear to offer a way to change the resolution, only the color depth. My first thought was that the sense pins on the display connector might be dirty or damaged, but looking at the Xceed board's connector, sense pins 4 and 7 aren't even connected, while pin 10 buzzes out fine and looks properly pulled to ground as expected for a portrait display. I was wondering if you all knew, how does the Xceed board know to use portrait resolution? Is there a jumper or software switch somewhere I have to set, or should it be able to automatically detect the display?
