bigmessowires
I've recently acquired a SuperMac ColorCard for my SE/30. One of the quirks of this card is that it displays a monitor selection GUI on the internal monitor after the "Wecome to Macintosh" appears, presumably using some code in the card's ROM. This behavior only works when booting System 6 and causes System 7 to hang, but if you boot in System 6 and make a monitor selection, it will be saved in PRAM and then you can boot with System 7 next time.
The strangeness is that the external monitor sometimes simply mirrors the internal display instead of extending the desktop area, and it does it in a broken sort of way that seems like a bug. The Monitors control panel shows that I have two monitors with different physical sizes, but the content is mirrored between both instead of creating an expanded desktop. The external monitor is 640x480 and it shows the 512x342 internal monitor contents in the top-left corner with empty space to the right and below. It also appears to be running the internal display in color mode, so some items like the close box in the window title bar become invisible. The mouse cursor can't be moved between the monitors, and only appears on the external.
I've narrowed down the mirroring problem a little bit. It may be caused by using a locked startup disk like a ROM disk. Or it might be related to using a ROM-inator, or to the specific version of System 7 used.
- SE/30 with ROM-inator, booting System 7.1.1 from the hard disk: Color Card works normally
- SE/30 with ROM-inator, booting System 7.1 from the ROM-disk in RAM-disk mode (press A while booting): Color Card always starts out disabled and must be enabled by opening and closing the Monitors control panel. After that it displays normally until the next reboot.
- SE/30 with ROM-inator, booting System 7.1 from the ROM-disk in read-only mode (press R while booting): Color Card always starts out disabled and must be enabled by opening and closing the Monitors control panel. After that it displays a mirrored image as shown in the photos, and the internal display tries to draw in color mode.
