robin-fo
You would need a LocalTalk to ethernet bridge and two AirTalks for thatIs it possible to use AppleTalk for iMac G3 with a Mac Plus with an AirTalk? Not sure if I am mistaken
I‘m not entirely sure if that‘s 100% correct.. Even the Mac mini G4 has an integrated ESCC.. But yes, it‘s not accessible.The iMac doesn't have that.
I wonder how difficult it would be to write an LToUdp bridge for open transport...
Any off-the-shelf wifi-to-ethernet bridge should do the job there - I haven't used it personally but I gather the Vonets VAP11G is a popular and easy-to-use choice for that.I asked about this way-back-when, but on the odd chance that something changed... Is there an ethernet version of the AirTalk in the works? For Macs that have an ethernet port (either built-in or add-on) but no wifi.
I have a TP-Link Deco mesh network. The Deco units have ethernet ports. I can connect my Mac SE (with ethernet card) directly to a Deco and it handles AppleTalk with no problem. Unfortunately, I want to move the Mac to another location that is too far from the Decos to run a cable.Any off-the-shelf wifi-to-ethernet bridge should do the job there - I haven't used it personally but I gather the Vonets VAP11G is a popular and easy-to-use choice for that.
The only snag is that not all wifi access points handle AppleTalk traffic correctly, so while something like that will work just fine for web browsing and AppleShare-over-IP, it may or may not work for AppleTalk.
Well, technically there is one iMac model (for sure the Rev. A and B tray loaders, maybe C and D too; the slot loaders for sure don't, as they're an all new design) that seems to have something that looks – and presumably functions – very much like a serial port feeding the IrDA transceiver. Whether it's implemented either as a fully functioning serial port via a discrete Zilog SCC or a custom integrated version, or as a limited port that electrically is only capable of supporting IrDA, I can't say. All I know is that it's there, so maybe something can be done with it.No,
LocalTalk relies on hardware features of the Zilog SCC serial controller in the mac. The iMac doesn't have that.
The Griffin iPort may have taken advantage of that fact. I installed one (and it’s still in there, to my knowledge) in my original rev. A iMac. Has a serial port right in it, and works in tandem with the irDA port. You could switch between the two with a control panel.Well, technically there is one iMac model (for sure the Rev. A and B tray loaders, maybe C and D too; the slot loaders for sure don't, as they're an all new design) that seems to have something that looks – and presumably functions – very much like a serial port feeding the IrDA transceiver. Whether it's implemented either as a fully functioning serial port via a discrete Zilog SCC or a custom integrated version, or as a limited port that electrically is only capable of supporting IrDA, I can't say. All I know is that it's there, so maybe something can be done with it.
To that end, has anybody ever tried plugging normal serial peripherals into that port? If so, what were the results? Was there any special software voodoo that had to be done?
c
I got a Vonets VAP11G-300 and tried hooking it up to the ethernet port of my SE… Annnnnnd it seems that this is one of those access points that does not handle AppleTalk traffic correctly.Any off-the-shelf wifi-to-ethernet bridge should do the job there - I haven't used it personally but I gather the Vonets VAP11G is a popular and easy-to-use choice for that.
Can the AirPort work as a wireless bridge to my main (mesh) WiFi network? Since it is older tech, I assume it is slower and less secure than modern devices. Will it impact performance or security for the rest of the network or just on devices that are connected to the AirPort itself?If you want an access point that shuttles AppleTalk properly…just buy an AirPort. Last gen if you want to make it simple.
Not sure what "MacCON" is. The SE works fine on the network I have (TP-link router, TP-link deco mesh WiFi devices) as is -- as long as the SE is connected with an ethernet cable. It even works if the ethernet cable connects the SE to a Deco mesh device which is communicating with the router wirelessly. My problem is that the place where I want to put the SE does not have easy access to the router or any of the Deco units.If you are trying to get a MacCON working with that SE, you need a router/switch that will allow you to manually set one of its ports to 10 ONLY. Any auto sensing stuff confuses the incredibly old SE cards and won’t work properly.
