mactjaap
Could you post a link to the update you mean?Ah now.. I've just been looking at the documentation for Netatalk and it'd seem that that functionality was added in v4.2.0 and your build is v4.1.1 from what I can gather? If that's correct is it safe to upgrade to v4.2.1 using the instructions on https://netatalk.io/install or would the steps be different because it's a customised installation location?
Apologies for the n00b questions. I used to have a fair amount of linux experience 25 years ago but I've just not used it much at all since the end of the 90s and frankly I can't remember what the heck I'm doing.
Netatalk is developing fast paced!
4.1.1 is from januari 2025. Version 4.2.1 is not even a week old.
So the stable version of the MacIPRpi will not always be cutting edge....
You can try to update and use the guidelines on https://netatalk.io/install
But not sure if everything will work. You can use the check-maciprpi.sh script to test.
